Arp Head/Main/Wheel Studs
Old Jun 22, 2005 | 12:01 PM
JonGTR's Avatar
New updated info for ordering Beta ARP Studs:
Main Studs:
Part #AM 3.800-1LB.........Qty 10 (M10x1.25 Studs) $5.12 ea
Part #200-8519............... Qty 10 (10mmID, .750"OD Black Washers) $0.89 ea
Part #300-8343................Qty 10 (10mm x 1.25 12pt Nuts) $4.03 ea
Head Studs:
Part #AM 4.500-1LB..........Qty 8 (M10x1.25 Studs) $5.49 ea.
Part #AU 7.250-1LB..........Qty 2 (M12x1.25 Studs) $11.62 ea.
Part #200-8519................Qty 8 (10mmID, .750"OD Black Washers) $0.89 ea
Part #200-8536................Qty 6 (12mm ID, 3/4" OD, Black Washers) $0.94 ea. *need 6 to shim the extra length of the stud*
Part #300-8343................Qty 8 (10mm x 1.25 12pt Nuts) $4.03 ea.
Part #300-8308................Qty 2 (12mm x 1.25 12pt Nuts) $4.33 ea.
Wheel Studs:
Part #100-7717.................Qty of 5 per pack (mitsu-evo8 studs)
Fits front exactly. To fit rear, machining may be required. Results may vary.
You will need open-ended lugnuts.
Torque Specs:
M10's = 60ftlbs. (with ARP lube)
M12's = 80ftlbs. (with ARP lube)
Rod bolts = 50ftlbs. (with ARP lube)
Add a couple lbs if using regular engine oil.
Old thread info:
I don't think this was carried over from HA.com so here it is:
Here is Red's original post:
"AM 3.800-1LB" Qty 10 (Main cap M10x1.25 studs) $4.21 ea
"AM 4.500-1LB" Qty 8 (Cyl head M10x1.25 studs) $4.62 ea
"Special 6.83" Qty 2 (Cyl head M12x1.25 studs) $24.56 ea
"200-8519" Qty 18 (10mmID, .750"OD black washer) $1.37 ea
"200-8500" Qty 2 (12mmID, .875"OD black washer) $$1.28 ea
"300-8343" Qty 18 (10mm x 1.25 12pt nut) $5.36 ea
"300-8307" Qty 2 (12mm x 1.25 12pt nut) $4.55 ea
The special bolts were not as expensive as I originally remembered. Total cost on all the equipment was a bit over $200 for everything as I outlined above. The "special 6.83" is a 12mm stud with a 1.25mm thread pitch that is 6.83 inches long. They may have a better (cheaper) alternative now...
They now have different prices. They also have a cross referenced part for the "special" bolt that is cheaper.
Updated by me:
Main Studs:
"AM 3.800-1LB" Qty 10 (Main cap M10x1.25 studs) $5.12 ea
"200-8519" Qty 10 (10mmID, .750"OD black washer) $0.89 ea
"300-8343" Qty 10 (10mm x 1.25 12pt nut) $4.03 ea
Head Studs:
"AM 4.500-1LB" Qty 8 (Cyl head M10x1.25 studs) $5.49 ea
"AU 7.250-1LB" Qty 2 (Cyl head M12x1.25 studs)
"200-8519" Qty 8 (10mmID, .750"OD black washer) $0.89 ea
"300-8343" Qty 8 (10mm x 1.25 12pt nut) $4.03 ea
These are "Jobber" prices. The retail will be roughly a $1 more per stud.
The special bolt/nuts/washer I will change as soon as I get the info from Dave Dickson as his ARP rep found a cross-referenced bolt. So like Red foresaw, there is a cheaper alternative now.
The guy was short with me and wouldn't look for anything I didnt know the part # to.
I called Hyundai to get other prices:
Rod bolts $2.50 ea
Main Cap bolts $0.39 ea
Head Gasket $95.03
So you could save about $50 by getting the main bolts from Hyundai.
Old Jun 24, 2005 | 03:39 PM
2uniq's Avatar
I recall calling ARP a few years ago and they never had the 2 Main Longer studs?
They had the other 8 in stock but NOT 2 of the longer ones?
SO is ARP selling alll of them now for the Tiburon?
Old Jun 24, 2005 | 04:45 PM
Jaws021's Avatar
dam thanx a lot man
Old Jun 26, 2005 | 09:21 AM
JonGTR's Avatar
DMDicks' rep actually took the time to look for an alternative for us. He crossreferenced it to another standard bolt. He's trying to find his receipt to get the part #.
Old Jun 26, 2005 | 11:07 AM
Loneshark's Avatar
Vehicle: 2000 Tiburon
so which bolts do i need to replace the exhaust cam journal bolts ?? and what a bout the vavle cover ??
i want to put the 1.8 cam in, but with new bolts
i dont understand what main cap and cyl head means
Old Jun 26, 2005 | 12:21 PM
JonGTR's Avatar
For the cam journal bolts, you can just get some cheap ones from your local hardware store. Take one for comparison and get a high grade bolt.
Old Jun 26, 2005 | 08:24 PM
Mad_john's Avatar
what is the total menu, i need to order everthing asap.. help me out brother's
Old Jun 30, 2005 | 10:58 PM
Viper966's Avatar
QUOTE (Mad_john @ Jun 27 2005, 02:24 AM)
JUST AN FYI
hyundai doesnt recommend changing the head bolts when the head is pulled...
its a tsb on hma service , but your welcome to if you want to (i still did )
Old Jul 1, 2005 | 06:25 AM
JonGTR's Avatar
I was told by my shop guy to re-use the head bolts also because they are already heat stretched. That's what he does to all of his personal motors. And they run 9's.
The only bolts you really need to worry about are the rod bolts if you're using the stock rods.
Old Jul 12, 2005 | 08:32 PM
Mad_john's Avatar
Well, after many time calling ARP and running around. waiting 3 week for a reply on the 2 speical m12 studs for the head this is what they quoted me... i am super pissed off. at this What the f*** doesn't even come close.. not when it was 24
bucks and now this!!! they are not speical in any way just they standard studs
2 of them 6.83 in long, no CF, no Gold, no tituiam. I dont ahhhhhhhhhhhhhh mad ash hell
[attachment=61:attachment]
