Aftermarket Crank?
yeah, that's definately one of the strongest internals
i can't imagine an aftermarket shaft would be that much lighter anyway, so if the stock crank can handle that kind of throw... i'd run with it too
The stock crank/block will handle 600+ WHP. If I remember right, the highest dyno out of Korea for a Beta was 702 WHP. That was with the stock crank, and the entire assembly balanced. Even the stock rods have been proven over 400 whp. They simply replace them when going over that point because of reliability.
Damn, I wish I still had Cheuk's email addy...
You'll run into tranny/diff/axle problems long before your block or crank give out.
