Hyundai Aftermarket
-   Turbo & Supercharge (Forced Induction) (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/)
-   -   1bar map to 3 bar (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/1bar-map-3-bar-74776/)
blitz Aug 20, 2013 05:52 AM
1bar map to 3 bar
Helloooo :)
My tibby is Map based, but 1bar GM map which is normal for NA car. The plan is to boost around 0.8 bar = 12psi. 2 bar map sensor will do the job , but I found 3 bar brand new GM sensor and I'm thinking if I will be able to run with this sensor and my Apexi Neo ?!
http://www.rpw.com.au/index.php?opti...=97&Itemid=120
When you check the characteristics of the Neo, can you please tell me will I be able to use 3bar map sensor without any ECU work ? Hopefully this " MAP/MAF transfer correction function " will let me do the job.
Thanx in advance :)
koreancorvette01 Aug 31, 2013 07:51 PM
Sounds like a headache waiting to happen. Look up Megasquirt. May you see the light.
blitz Sep 2, 2013 04:18 AM
I might go this way !!! As some other members told me it's better to sell the Apexi sh*t and buy standalone. Mega is cheap, but the tuners here are stupid ass hell, so I have to do everything by myself ! I don't want to mess with all the electronics , but it seems like I don't have a choice if I want to do things right.
Thanx for the advice ;)
