1bar map to 3 bar
Vehicle: 97' Hyundai Coupe
Helloooo
My tibby is Map based, but 1bar GM map which is normal for NA car. The plan is to boost around 0.8 bar = 12psi. 2 bar map sensor will do the job , but I found 3 bar brand new GM sensor and I'm thinking if I will be able to run with this sensor and my Apexi Neo ?!
http://www.rpw.com.au/index.php?opti...=97&Itemid=120
When you check the characteristics of the Neo, can you please tell me will I be able to use 3bar map sensor without any ECU work ? Hopefully this " MAP/MAF transfer correction function " will let me do the job.
Thanx in advance
Thanx in advance
I might go this way !!! As some other members told me it's better to sell the Apexi sh*t and buy standalone. Mega is cheap, but the tuners here are stupid ass hell, so I have to do everything by myself ! I don't want to mess with all the electronics , but it seems like I don't have a choice if I want to do things right.
Thanx for the advice
