Toughen Up 1.6 Accent/getz Gearbox
Old Mar 12, 2010 | 03:23 AM
Ryanator's Avatar
Vehicle: 2003 Hyundai Accent 22PSI Boost
Default Toughen Up 1.6 Accent/getz Gearbox
hey guys
thinking seeing as im pulling out the motor for a full rebuild, thinking of tricking up the gearbox a bit.... gearbox for 1.6L Accent/getz/verna/click...
I know i can get a Phantom Grip LSD, or a full Quaife replacement LSD...
Already have a nice new clutch - rated for 450hp, so i know that wont be a issue
What should I look at doing? I am also thinking of doing my drive shafts but getting custom ones to use Mitsubishi Cordia Turbo CV's as they are indestructable, Got a budget of say $1300 USD
Cheers Ryan
Old Mar 12, 2010 | 10:35 AM
No idea what anything costs in Australia, so I won't concern myself too much with the budget.
The Alpha trans has kept getting better basically since year one up until now. Getting a newer gearbox will add to reliability. Here newer gearboxes are less than $500.
If you get a Quaife LSD, you'll be splitting your power between the two axles equally, basically stressing them each as much as making half the power would as a one wheel wonder.
If you want to really add to the gearbox's reliability, get it cryotreated.
Old Mar 12, 2010 | 01:36 PM
Ryanator's Avatar
how much do quaife LSD's cot these days for the accent?
Whats involved with getting the internals cryo treated?
what parts will get done?
does this include synchro's?
Cheers Ryan
Old Mar 12, 2010 | 10:24 PM
Looks like retail is around $1350 USD.
You can cryotreat whatever parts you want to get done, up to and including every single metal part even the housing. I would get the entire differential assembly done if I was doing it at the very least.
They just freeze the parts to incredibly low temperatures at a specific rate.
Old Mar 13, 2010 | 12:17 AM
Ryanator's Avatar
Reaistically what are the parts I should be getting treated... Just because im already gonna spend close to 7000AUD rebuilding and getting the car back on the road
Cheers Ryan
Old Mar 13, 2010 | 01:56 AM
Differential, synchros, and gears.
I don't know how much more it would be to do everything though. I would at least ask.
Old Mar 13, 2010 | 02:51 AM
342Four's Avatar
Vehicle: '97 X3
ryan....if your going to this effort then start with a getz g/box case and use 1,3,4,5 from the getz and the LC2 2nd
youd get: 3.615, 2.053, 1.37, 1.061, 0.825 FD = 4.056
as your ratios
M5AF3 X3 Excel: 3.462, 2.053, 1.37, 1.031, 0.838 Final Drive = 3.842
M5AF3 LC 1500: 3.615, 2.053, 1.37, 0.971, 0.825 FD = 3.65
M5AF3 LC 1600: 3.615, 2.053, 1.37, 1.031, 0.825 FD = 3.842
M5AF3 LC2 1600: 3.615, 2.053, 1.37, 0.97, 0.78 FD = 3.842
M5AF1 MC 1600: 3.615, 2.053, 1.37, 1.031, 0.837 FD = 4.056
Getz 1300: 3.615, 1.95, 1.37, 1.061, 0.825 FD = 4.056
Old Mar 13, 2010 | 01:49 PM
Ryanator's Avatar
lol, already have a getz gearbox with a LC2 second gear... Mazfix in brisbane did it for me smile.gif lol and another Hyper Ausralia member here 342four lol.
Cheers Ryan
