tob keeps going bad!!!!!!!!!!! wth??
Old Feb 13, 2012 | 02:47 PM
97dsscobra's Avatar
Vehicle: accent
Default tob keeps going bad!!!!!!!!!!! wth??
okay so its a 99 accent with a 1.8 beta motor, elantra trans, ebay clutch kit with a junkyard 2.0 flywheel.
when i release the clutch pedal it makes a noise nd its hard to go into any of the gears.
this happened too when i had the accent 1.5 trans too nd it would break the preassure plates in half
any help would be apriciated and helpfull.
Old Feb 13, 2012 | 08:46 PM
It can't be all lined up/aligned properly. Nothing binds? Everything that's supposed to be mated flat&flush together is tight?
Old Feb 13, 2012 | 09:13 PM
97dsscobra's Avatar
Vehicle: accent
yeah im sure it was all done good, could it be that maybe the crankshaft went bad when one of the preassure plates broke in half or maybe the flywheels bend? or could it be that the clutch was one of cheap ones ordered from eaby? what could happen if the tob is installed wrong??
Old Feb 13, 2012 | 09:30 PM
Did you not have the flywheel resurfaced when you installed the swap?
If the TOB is installed wrong, I'd think you would notice it pretty much immediately but I haven't done that (yet).
Old Feb 14, 2012 | 06:41 AM
97dsscobra's Avatar
Vehicle: accent
Yeah flywheel was resurfaced, nd ill try one more time. Ill you know how it goes. Thanks for your help.
Old Feb 14, 2012 | 08:30 AM
wheel_of_steel's Avatar
As a desperate attempt not to remove the engine/trans, maybe unbolt the slave cylinder and peer inside the dust cover? It might hint at what is wrong, and if you run the car with no slave cylinder, you could rule out hydraulic/adjustment issues.
I can't say I've ever heard of this particular set of noises/conditions though. Is there a troubleshooting flowchart on webtech maybe?
Old Feb 14, 2012 | 11:03 AM
97dsscobra's Avatar
Vehicle: accent
what do you mean run the car without a slave cylinder..ive never heard of that.
im okay to try anything.
Old Feb 14, 2012 | 11:17 AM
That's exactly what I mean. Just don't press the clutch pedal while the slave cylinder is disconnected, or you'll be rebuilding that sucker!
Old Feb 14, 2012 | 12:48 PM
97dsscobra's Avatar
Vehicle: accent
Oh okay I thought you wanted me to do that... I got a little confused.
