Stock flywheel weight
Old Nov 4, 2010 | 08:14 AM
tibby01's Avatar
Vehicle: 2001 Tiburon
Default Stock flywheel weight
Anyone know off hand what the weight is of the stock flywheel? Curious to see what the difference is between stock and a Fidanza.
Old Nov 4, 2010 | 08:23 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
Roughly 15-16lbs iirc
Old Nov 4, 2010 | 08:43 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Well it is noticeable by far, your talking about a less than 8 lbs flywheel, Not sure exactly i weighed mine when i did the swap, mine was about 18 lbs, (also had mine shaved down alot to make it as light as a could with one or grinds left in it.)
I would say it is a good mod, but if your looking to free up major horsepower or something, i would use that for nitrous or towards a turbo setup first.
then go with the light weight flywheel, to help release the beast!
