Squeaky clutch pedal
Old Jul 28, 2010 | 07:58 AM
Deegatron's Avatar
The advantage of a lighter grease is that you could likely remove the top bushing and use some sort of long syrunge to get a little grease into the bottom bushing without splitting the enging/trans.... the light grease would flow into the lower bushing rather than just sitting on it like a heavyer grease would..........
