short shifter
after installing and using my short shifter
(from shark racing santa was good to me this year) it always felt very stiff almost like shifting thru sand. so i reinstalled a stock shifter-got that for free from the same auto recycler that i got my leather seats from. i went to work on the short shifter first the two short tubes of the lower arm were not straight or parallel straightened them. second-removing all the metal burrs from all the punched holes. third- the nut that is molded into the plastic shifter base wasnt flush with the surrounding plastic-5 minutes with a wood chisel paring away the plastic flush with the steel nut fourth- got rid of all the plastic bushings and replaced them with oillite bushings even made a new round brass bushing that fits into the lower arm- use lapping compound so that there is no play there. fifth- made a bracket that fit under and around the plastic shifter housing to support the assembly (with cutting a hole in the housing to make room for the longer arm of the short shifter there was some "flexing of the housing) i guess what i did was to "blueprint" the whole assembly. use plenty of grease i reinstalled the whole assembly yesterday and lo and behold it now shifts like a dream . all traces of "stiffness and gritty shifting" are a thing of the past |
That's pretty neat. did it cost you anything?
Nice! :D
Do you want to do mine as well? :cool: Z? |
the only thing it cost me was buying
a 25/64 dia reamer (.390) ($15.00) but now i have the tool!! the rest of the stuff came from where i work. i work for a machinery manufacturing co. couple of hours in the shop-lunch time and stay late after work was all it took. as far as doing it for anyone else- i would need to have your shifter assembly for a couple of days-the complete assembly- plastic base and all other parts-dont need the shift knob. also if you wanted a brass bushing for the lower lever and if you wanted postiive stops instead of the silly rubber ones. i already have a stock shifter assembly completed with the brass bushings(i need something while i was modifing the short shifter assembly). this moves so sweet finger tips it all it takes. but the throw is as a stock unit. |
<div class='quotetop'>QUOTE</div><div class='quotemain'>Originally posted by dds designs:
but the throw is as a stock unit.</div> If I'm understanding this correctly, then the throw is not reduced with the short shifter. And if the throw is not reduced, then what is the point of having a short shifter? I'm confused :confused: wink.gif |
i have two shifter assemblies!
the one in my car now has the short shifter it reduces the throw as it was designed for. i replaced all the white plastic bushings with oillite or brass bushings. the second shifter assembly has a stock shifter assembly on it. the throw is the same as stock but i did replace all the white plastic bushings with the same oillite and brass bushings. both assemblies have the adjustable postiive stops on them. hope this clears things up |
