rpm/mph poll 5spd only
Old Mar 25, 2003 | 07:03 AM
Shadohh's Avatar
Default rpm/mph poll 5spd only
I wanna hear form Tiburons, Elantras and Accents and Sonatas.
Sadly HMA is wrong at times.
So I wanna take a survey.
Only Manual Transmission Ppl please reply.
Please this is important for all of us. so dont guess. If you wana add, get in your car and drive and take attention.
And drive safe!
To help out.
Post here, list your Model/Year/Country
List rpms at 80mph in fifth and rpms at 60mph in 4th.
list wheel size exmaple: 15/195/50
You need to have NOT done a swap. Or had your transmission swapped out. As these transmission would not be linked to your car model.
THANK YOU FOR YOUR HELP
Please do not post things unrelated to this topic.
[ March 26, 2003, 06:26 AM: Message edited by: Shadohh ]
Old Mar 25, 2003 | 09:54 AM
AllBlackTibby's Avatar
3700 or so in 4th at 60mph, 3800 in 5th at 80.......wanna know what 100 was??
EDIT:
2001 Tib, USA, stock tires.
[ March 26, 2003, 05:44 AM: Message edited by: AllBlackTibby ]
Old Mar 25, 2003 | 09:30 PM
Shadohh's Avatar
Model? year? Country? Tire size?
Old Mar 25, 2003 | 09:46 PM
Skitzo's Avatar
2k1 Tib, USA, 195/55R15
~3500 @ 60mph 4th
~3800 @ 80mph 5th
Old Mar 26, 2003 | 05:02 AM
ONLY1DB's Avatar
2000 tib 205/50 r 15
3900 @ 60 in 4th
4100 @ 80 in 5th
2.0 and stock gauges
[ March 27, 2003, 06:55 AM: Message edited by: ONLY1DB ]
Old Mar 26, 2003 | 05:12 AM
bryfx's Avatar
there are also gear ratio differences between 1.8 and 2.0L
Gear 1.8L 2.0L
First 3.462 3.308
Second 1.950 1.950
Third 1.393 1.393
Fourth 1.061 1.061
Fith 0.878 0.837
Final 3.650 3.842
you might want to include your engine size, and if its the original size
or not.
Old Mar 26, 2003 | 06:41 AM
JAWS 021's Avatar
you should also add, if you have tampered with your gauges
Atleast so we know it could be a bit less than 100% accurate...
[ March 26, 2003, 01:43 PM: Message edited by: JAWS 021 ]
Old Mar 26, 2003 | 07:22 AM
2000 Elantra 195-60-R14
60 MPH in 4th is 3200 RPM
80 MPH in 5th is 3400 RPM
[ April 04, 2003, 12:21 AM: Message edited by: Random ]
Old Mar 26, 2003 | 04:31 PM
Shadohh's Avatar
bryfx:
Gear 1.8L 2.0L
First 3.462 3.308
Second 1.950 1.950
Third 1.393 1.393
Fourth 1.061 1.061
Fith 0.878 0.837
Final 3.650 3.842
or not.
Bryfx, I assume you got those gear ratios from HMA.
If you read my post...Those are known to be inaccurate.
Hence why I am collecting rpm/mph.
to see which cars have different gearing.
Old Mar 26, 2003 | 04:58 PM
bryfx's Avatar
No, I got them from my shop manual.
inaccurate or not, there is obviously a difference that needs
to be accounted for.
