quaife differential
Old Feb 8, 2003 | 01:30 AM
Sh@rk-P.R.'s Avatar
Default quaife differential
does anyone knows if quaife is selling now the differential for the tiburons? I heard that this differential has a limited life garanty and that does not need to change oil never, instead of kaaz that needs to change the oil every certain amount of millage. If someone knows let me know, thanks
Old Feb 8, 2003 | 06:10 AM
ignoreance's Avatar
Vehicle: 2010 Honda VFR1200
check out the group buy they are working on getting one made...
Old Feb 8, 2003 | 04:26 PM
turbulence's Avatar
no, you still need to change the oil at certain intervals. however, the quaife is "indestructable." just about anything you can put through it with your beta, it will handle. i suppose if you manage to put 3,000 hp through it, it might have a problem. wink but i don't suspect that's the case. :-d if you get 3,000 hp out of your beta, give me a call. poke
Old Feb 9, 2003 | 01:57 AM
Sh@rk-P.R.'s Avatar
jajaj thanks for the info i really apreciate it
Old Feb 9, 2003 | 10:36 AM
http://www.hyundaiaftermarket.com/noncgi/u...c;f=35;t=000009
