New LSD available?
Old Dec 12, 2002 | 08:33 PM
Default New LSD available?
Well, I ran into this today. Tell me what you think. I did a search and haven't seen this anywhere on the boards...
Phantom LSD
97-01 TIBURON-(4 cyl.) PART #903-GOLD $299.00
03' TIBURON (6 spd-6 cyl.) PART #908-GOLD $349.00
95-01 ACCENT PART #903-GOLD $299.00
[ December 13, 2002, 03:33 AM: Message edited by: REDZMAN ]
Old Dec 12, 2002 | 08:41 PM
Agarwal's Avatar
It's a pretty old device; basically, what it does is forcing the two gears in the differential to spin together, using some strong springs pushing 2 blocks of metal.
It does the job pretty good (condidering the price) up to about 250hp; even then, you can be pretty sure that you'll destroy the differential before damaging the Phatom Grip, as it's very strong. That's what Onpol was using when he had ~250hp.
Old Dec 13, 2002 | 02:24 AM
Cecil's Avatar
http://www.hyundaiaftermarket.com/noncgi/u...c;f=40;t=000041
Old Dec 13, 2002 | 04:35 AM
Shadohh's Avatar
The two inner plates push against the gears, and pushed them against the inner transmission cover.
Using the two plates and the wall of the bellhousing like clutches. what will happen on a higher horsepower, is the gears will begin to cut into the casing.
Old Dec 13, 2002 | 09:42 AM
rubenz2K1's Avatar
whats the difference between that and a true LSD.
Old Dec 14, 2002 | 01:50 AM
Read This for how "true" LSD's work
