How much power can the stock beta trannys take?
Old Jan 12, 2011 | 12:14 PM
[QUOTE=Tibbi;614701]the auto won't even hold up under stock power[/i] D:
Old Jan 12, 2011 | 12:54 PM
Tibbi's Avatar
Yeah, after paying someone else (like a damn fool) to fix it and going through several more rebuilds and whole new units, I just gave up and said it's time to swap to manual.
This spring/summer I'm going to shelf the Tib for a few weeks and finally get rid of that nasty old auto. I have been collecting the parts for the swap, and I'm going to do my brake upgrade and suspension mods at the same time.
What this forum needs is a list of the available mods for the Beta 1 and 2 transmissions.
We have the info overload for boosting and bulletproofing, but what about the trans? Someone put that together and sticky the bish!
I can has rep naou?
Old Jan 12, 2011 | 03:00 PM
Regit's Avatar
Vehicle: 2000 tib
02 elantra tranny(manny) with m&tec lsd,no problems for 4 years at 300 whp with at least 100 passes at the track and shes still fine...
Old Jan 12, 2011 | 04:49 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
What LSD is that? can you post a link pleas?
Old Jan 12, 2011 | 11:38 PM
Regit, this is only a little over 200% of stock power and clearly not an indication of reliability.
Old Jan 13, 2011 | 04:20 AM
blitz's Avatar
Vehicle: 97' Hyundai Coupe
Here in Bulgaria almost all tiburons are grinding synchros...from 1-2 gear it grinds even if I drive slow!!! I'm about to change the clutch so what you guys will suggest me? Some say leave it like this, but I prefer to repair it if it's not too hard
Stocker may be right, but 90% of the tibbs I know are having issues with the gearbox and most of them are stock.
Some videos where you can hear the grinding noise
http://www.youtube.com/watch?v=EnXT8zv-0No watch from 45sec
http://www.youtube.com/watch?v=TGhIW_UKJDI watch from 50sec
Old Jan 13, 2011 | 06:08 AM
I don't know if you can get it over there, but if you can lay hands on some Redline MT-90 GL4 gear oil, you might try it. Many members have reported grinding goes away (probably temporarily) with Redline in the transaxle.
http://www.redlineoil.com/Products.aspx?pcid=7
Old Jan 13, 2011 | 10:28 AM
blitz's Avatar
If I can get it I'll try it for sure I'm 99% sure that the noise is coming from the synchro, but a friend of mine told me that his tib is grinding also, but the noise is coming from the gearbox not like mine ( around the gear stick )?!?
Old Jan 13, 2011 | 12:09 PM
Sometimes vibration can be transmitted and it sounds like it comes from somewhere else.
Old Jan 13, 2011 | 02:23 PM
blitz's Avatar
I was thinking the same thing Hopefully I'll find this Redline MT-90 GL4 oil...
