Clutch Suggestions??
Old Jan 14, 2003 | 03:19 AM
alz99's Avatar
Vehicle: FX Coupe
Default Clutch Suggestions??
What clutch would people recommend with the CNK Turbo Kit.?
The tib will be a daily driver with med - high boost. I have an idea but wanted to see what fellow tuners would use.
Thanks in Advance. wink
Old Jan 14, 2003 | 04:26 AM
JAWS 021's Avatar
you should use the search feature...
you will find millions of arguments about this subject
Try searching for clutch in the engine/intake/exhaust forum
This forum has also had a couple of discussions in the last couple of months regarding this
Old Jan 14, 2003 | 10:58 AM
alz99's Avatar
Vehicle: FX Coupe
Yeah thanks
[ January 14, 2003, 06:03 PM: Message edited by: alz99 ]
