Hyundai Aftermarket
-   Transmission, Clutches, Shifters (https://www.hyundaiaftermarket.org/forum/transmission-clutches-shifters-30/)
-   -   Can you fit a Beta Gearbox on Alpha Engine? (https://www.hyundaiaftermarket.org/forum/transmission-clutches-shifters-30/can-you-fit-beta-gearbox-alpha-engine-73004/)
Antonyr123 Mar 23, 2013 05:18 PM
I Don't wanna buy a Alpha Box if the Beta one will fit. Because i had a beta swap engine. all my sensors and Cables have been converted for the gearbox.
Im not sure if the driveshaft/Starter/Bolts will line up.
Is anyone 100% sure ?
Juanra Mar 24, 2013 12:57 PM
What do you have and what do you want to do?
Antonyr123 Mar 25, 2013 12:13 PM
i have a 2008 ish ahlpa engine.
i currently have 2.0 beta. but for legal reason i need to refit a OEM engine.
I dont have a alpha gearbox. So it all line up if i fit the beta gearbox ?
Juanra Mar 25, 2013 12:22 PM
yes you can, you will need a alpha 1.6 flywheel.
Antonyr123 Mar 25, 2013 02:42 PM
we only have 1.5 alpha engine i think. unless the 1.6 is in the newer LC2
what is weird is my 2002 1.3 alpha as a smaller flywheel and clutch as my newer 1.3 had.
anychance the newer 1.3 alphas was blessed with the 1.6 flywheel/clutch ?
if gearbox fits and bolts up would it be ok ?
Juanra Mar 25, 2013 04:29 PM
I have know idea about the 1.3L, you will need the 1.6L flywheel because is will directly fit the pressure plate.
Antonyr123 Mar 25, 2013 04:36 PM
so if my beta gearbox fits and slides into the alpha pressure plate/flywheel, It should work ?
do i need to use std alpha gearbox mounts ?
Antonyr123 Mar 25, 2013 04:45 PM
Clutchs..
1.3 2006
Cover Diameter(mm) 215
1.6 2003
Plate Diameter(mm) 215
So if they use same Clutch plate is there a chance maybe Beta gearbox will fit without flywheel change? Will 2.0 Beta Flywheel fit the Alpha to save spending close to $200 on a flywheel ?
Juanra Mar 25, 2013 04:48 PM
Alpha uses push pressure plates, Beta uses Pull so you cant use alpha pressure plates.
Antonyr123 Mar 25, 2013 04:51 PM
This is where it gets confusing.. lol The 2.0 Beta is also uses 215mm Pressure plate.
So can't i fit the Beta clutch and Pressure plate right onto the Alpha Flywheel ?
I.e If the beta Clutch/Pressure plate bolts too the Alpha Flywheel. I can Tighten down the gearbox. Should it be ok ?
From 1999 till 2005 Hyundai Used the 184mm Clutch Kits. (Will Require a new Flywheel)
From 2006 till 2008 Hyundai Used the 215mm Clutch Kits. (Same size as Beta Kit / 1.6 Alpha)
