turing a/c on causing stiff brake pedal
Old Jul 22, 2011 | 05:21 PM
seanhawn19's Avatar
Vehicle: 2004 Hyundai Accent
Default turing a/c on causing stiff brake pedal
I own a 04 accent, 1.6L DOHC. Now that it is summer I have started using the a/c. When I turn it on and press the brake it feels like I am not going to stop. The brake pedal is all the way to the floor and the car is still moving. Will still stop but over a further distance then when the a/c is off. The brake pedal feels stiff like I have no brake booster assisstance. As soon as I turn off the a/c the brake feels less stiff and normal. The car stops fine. What could cause this? Vaccum leak? Is there more or less vaccum with the a/c on? The faster I am going the more normal the brake feels with the a/c on. It is when I am slowing down that the brake feels like the brake booster is not working. But only with the a/c on. As said the brake is fine with the a/c off.
So I have not been using the a/c
Old Jul 22, 2011 | 05:31 PM
EclipseMTL's Avatar
I have the exact same problem in my 02 GL, only mine becomes spongy instead of stiff with the a/c on. Any ideas would be great!
Old Jul 22, 2011 | 07:00 PM
I don't know about your cars, but mine has a harness of vacuum hoses to actuate something in the air conditioner. They all go up to the A/C control panel on the dash and down to who knows where. If one of those if off or broken, it could be a huge vacuum leak.
Old Jul 22, 2011 | 07:26 PM
seanhawn19's Avatar
So a vacuum leak in a hose dealing with the a/c could cause loss in vacuum towards the brake booster?
Old Jul 22, 2011 | 09:42 PM
There is only the one source of vacuum, brother.
Old Jul 23, 2011 | 09:05 AM
seanhawn19's Avatar
I know there is only one source of vacuum. What I meant is that it is causing vacuum loss from one of many vacuum hoses.
Old Jul 23, 2011 | 01:11 PM
Or more than one. A leak anywhere affects the whole system.
Old Aug 4, 2011 | 07:46 PM
seanhawn19's Avatar
Does anyone know where I can get a diagram the the whole vaccum set-up? I checked out the hyundai service site and didn't see it. I checked all the vaccum lines running to the intake but can't see any lines that run to the a/c. You got the brake booster, pcv, the inlet line byside the pcv, two lines from the coolant under the intake, and the evap line. Any others?
Does the whole climate control run the heat and a/c? Sometimes with the a/c turned off, it feels like I got loss of power like I do with the a/c on. And a few times this summer I had condencation dripping from under the car and the a/c wasn't on, as well as, the air felt cool through the vent. On the flip side, sometimes if I had the a/c turned off with the temperature set to cold, I would get hot air like the heater was on coming through the vent. Any ideas on what could cause this? I know the temperature dial controls just a flip from hot to cold and can hear it moving side to side.
Thanks
Old Aug 5, 2011 | 12:18 PM
Dude you have more problems with this car...
There should be a vacuum diagram under the hood
Old Aug 5, 2011 | 06:37 PM
seanhawn19's Avatar
What can I say. If I knew I could get money through insurance I would set it ablaze. The vacuum diagram doesn't show the a/c vacuum setup.
