Gauge Face Diy / Dash Removal *pics 11/26/05*
It's your settings in windows or IE mang, I clickon it and it gets HUGE.
Download it or change your settings.
checked your diy, according to #11 I must cut where needed.. is it ok to put a switch with a 10 amp fuse inline to turn the power off when I want? I've also read you have to disconnect the old lights cause they draw power fr the other lights? hope this is not true.. Does anyone have an actual pic of the power wire I need to splice into(i'm not that bright). thanks ps you guys & gals are great!
1. Don't post the same question in multiple threads.
2. In your other thread Tibby01 told you what wire to tap into. The Green/White wire on the back of the Dimmer switch.
3. Why would you put in a extra swtich? Don't do it, otherwise you could go to turn on your lights some day, your gauges won't be lit, and you'll get into an accident while trying to switch them on.
4. Leave everything plugged in.
Shit. It would seem so. Please PM Javageek about it. I hope we didn't lose EVERYTHING I had uploaded.
