::THROWDOWN:: P2R Genesis Throttle Body Spacers Now For Sale @ Throwdown Performance!!
http://throwdownperformance.com/incl...ogo2-small.png http://throwdownperformance.com/imag...es/p2rlogo.png http://www.throwdownperformance.com/images/P332-2.JPG Available in SILVER, RED, and BLACK! http://throwdownperformance.com/images/p2rspacer.jpg **Picture only for demonstration purposes** What does a throttle body spacer do? A throttle body spacer increases the space between the throttle body and the intake manifold (the spacer itself is 3/4" and with two throttle body gaskets is approx 1") which adds more volume to the intake manifold by increasing the plenum volume. The thermal gaskets themselves isolate the heat in between the TB and the IM and as we've seen with other thermal products, lower engine temps = more power. Gaskets are not needed for the install but are usually an easy addition since you already have the TB disconnected. On various platforms we have seen gains of approximately 4-6 hp to the wheels. What are the two holes on the spacer? This is an added feature that we added for the Genesis spacer. The port holes allow you to tap in for nitrous, different gauges, etc. This added feature also gives the spacer features of a vacuum block. If not needed, just use the included plugs to close them up. :bananadance: 2.0T Spacers Now Available for Purchase! 3.8 V6 coming soon! :beercheers: Spacer : P2R - Throttle Body Spacer - 2.0T Genesis Coupe Spacer Package w/ 2 Thermal TB Gaskets : P2R - Throttle Body Spacer + 2 TB Gaskets - 2.0T Genesis Coupe 3.8 V6 - Silver available late this week, early next - Black and Red available late next week! PRE-ORDER HERE! |
Orders shipped - all spacers in stock!
We recently worked with one of our valued brands, P2R Power Rev Racing to release throttle body spacers for both the 2.0T and 3.8 V6 Genesis Coupes. Today one of our customers stopped by P2R and got the mod dyno'd... check out the graph below! 5.7whp gain! Hope this is useful for you guys looking for the next easy bolt on mod!
http://www.throwdownperformance.com/...SpacerDyno.jpg https://fbcdn-sphotos-a.akamaihd.net...45294208_n.jpg |
Maybe somebody with more knowledge than me can answer this. Would the 2.0L spacers for the Genesis fit Beta motors out of the RD Tibs? I don't know much about the Genesis motors except size. I haven't had the time to see if the 2.0 is just a turbo Beta II.
That's a good question, I'm not sure without seeing them side by side unfortunately, but if you have any measurements and want to compare drop us a line at sales@throwdownperformance.com and we'll compare for you :)
Also, on the 2.0T there is good chances that this will also work on the Sonata, Optima, etc. and we will be doing some testing on that shortly. |
Not the same motor.
