Tire Pressure
Old Nov 14, 2002 | 04:27 AM
Robert's Avatar
Vehicle: 01 Tiburon
Default Tire Pressure
I just got a new set of rims and tires, and I was wondering how much air pressure I should have in the tires. They're Kumho 711 205/40/17's. They came with like 38 or so PSI in them. Is that about the correct amount?
Old Nov 14, 2002 | 11:12 AM
xxxmonoxidechild's Avatar
different tires need different psi. i know my 205/40/17's need 50 psi which is really high. just do what i did, call the place that installed your tires and ask them, i figured it was 35 but they seemed overly soft so i called.
Old Nov 15, 2002 | 02:41 AM
Robert's Avatar
Vehicle: 01 Tiburon
I did call the place I ordered the rims and tires from. The guy there didn't really know what he was talking about. He said they needed anywhere between 32 and 40 psi. What kind of tires are on your rims?
Old Nov 15, 2002 | 03:20 AM
stickshift's Avatar
Vehicle: 2000 Tiburon
Does it not say on the sidewall of the tire what the recommended maximum inflation pressure is? It's usually there... you may need a magnifying glass, though as it can be hard to find.
Old Nov 15, 2002 | 03:28 AM
Old Nov 15, 2002 | 04:11 AM
Robert's Avatar
Vehicle: 01 Tiburon
Yeah, it's got the max air pressure on there. I think it's like 44 psi or something. But you're not supposed to run them at full pressure I didn't think.
Old Nov 15, 2002 | 06:31 AM
MADTIB's Avatar
xxxmonoxidechild:
I have the same tires!! They do rock!!
I keep about 35psi in mine.Are you sure 40-50psi is safe?? That seems pretty high to me. eek!
Old Nov 15, 2002 | 08:06 AM
turbulence's Avatar
on the inside of the driver door, hyundai has a label that tells you what pressure to have the tires at certain weight loads. however, those are for stock tires. it says to have 30psi on the stocks, but like monoxide said, he had 35 and they seemed soft. i would check around. like just run by firestone and ask one of the guys to look at your tires and tell you if they look low. i mean, it's not an exact science, but if the guy knows his s**t, he should be able to give you some insight.
Old Nov 15, 2002 | 03:59 PM
MADTIB:
if u read the side wall, it says 50 psi, i run them at 42-45.
Old Nov 18, 2002 | 05:30 AM
MADTIB's Avatar
50psi is probably max.
