Suspension for Hyundai Tib 1.6?
Old Jan 15, 2003 | 09:45 PM
JasonLEL's Avatar
Default Suspension for Hyundai Tib 1.6?
In Singapore, they have Hyundai Tib 1.6 (97'/98')
I would like to know does the suspension system for Tib 1.6 fit into Tib 1.8 (97')? Are both or the suspension system the same?
Old Jan 15, 2003 | 11:29 PM
Yes, the suspension is the same, but the 1.6L gets smaller/thinner swaybars.
Old Jan 16, 2003 | 04:46 AM
Shadohh's Avatar
probably has a different spring set to.
The automatic and manual tiburons use a slighty different srping on the front end. becuase of the different weight between the m/t and the auto
Old Jan 16, 2003 | 08:42 AM
JasonLEL's Avatar
Hmmmmm I'm not so concern about the spring, but I'm more concern about the absorber(shock).
Will this Tib 1.6 (98') absorber fit into Tib 1.8 (97')?
Coz I get to know monroe manufacture Tib absorber, but it didnt specify if it is for 1.6 or 1.8.
Old Jan 23, 2003 | 08:09 AM
Zman's Avatar
Hi, it feels good to post again...
Don't worry too much about ratios, they share the same suspension components (the spring is the same size: diameter and length, and the shock assembly is the same also. If they have different ratios (which I seriously doubt) and you're going to put aftermarket parts, they are the same for any Elantra or Tiburon 1.6, 1.8 and 2.0.
I have installed in my 96 1.6 Elantra a set of H&R sport springs for a 2.0 Tiburon, and it feels great.
