Images inoperable on blog without login
The blog images cannot be seen without login. Video media works. There is no notice that images are not available without login so it appears to a new viewer that images are simply broken and the poster screwed up.
I don't see a reason to block images. That means whenever someone posts a blog, it is only in it's original form in this community. It should be open to all. I can see having the user log in to comment, but images contain alot of information and the content is supposed to be open for the public to view for events like HyundaiUSA postings or any other postings. |
Apparently the BBCode isn't processed unless you're logged into the forum.
I would suggest posting in HTML format. There's a drop down box at the bottom of the blog post to make the selection. The only thing you'll have to change is the image BBcode to [img][/img] code. This will also make it easier for people to use the "Syndicate Blog" feature. If you post pics in HTML format, guests will be able to view images. |
Ok. Thanks. That worked. This link is going to be automatically posted on a network of hundreds of websites over the next day or so https://www.hyundaiaftermarket.org/f...ovios-charger/ . It's likely to draw alot of hits. I wouldn't want it to look shabby.
Thanks majik! :)
DTN...good work! :thumbup: |
