Part out thread A LOT ADDED 3/22/05 1.8 fuel rail, fender, etc etc etc
Old Mar 8, 2005 | 02:33 PM
  #161
Tibbychick's Avatar
BIG UPDATE guys! I added the 1.8 head, manual shifter, and speakers. Im also going through and cleaning up some unessesary posts.
The specs on the amp are as follows:
Model # PB-230P
Serial # 403036
On the right side, its got wire inputs for +12V, Ground, REM, +- RR, -+ RL, +- FR, -+FL (so all the negative and positive inputs for all for speakers) and a fuse.
On the left side, you've got a high input and low input for the front and rear, and you can adjust the level.
Thats about all I can tell from looking at it.
Any other questions, just ask.
Old Mar 8, 2005 | 02:37 PM
  #162
tibu971.8L's Avatar
Old Mar 8, 2005 | 03:29 PM
  #163
Tibbychick's Avatar
Yes sir, Ive got one airbag out so far, just gotta pull the steering wheel out and get the other one. I also have the harness for the gauges that you were asking about.
Now that we stripped the car down some more, I have a better idea of what I have for sale and can answer peoples inquiries. I went through the whole thread. Look for you name and please let me knowif you are still interested in the part you roiginally requested. If not, I will sell to someone else.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Orginally posted by Supercow on 01-15-2005:
tibbychick, do you still have the 2" radio surround? I also need the little clip on the inside of the headlights that hold the bulb in... don't ask. ( just figure with 3 tibs you got one, oh btw it's for the low beams)</div>
I have the surround but no the clip. Do you still want the radio surround? Please let me know.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by deestibo on 01-18-2005
hey do you still have the intake manifold on the 2.0 and if so how much thanx</div>
Yes, its from the 1.8 but is the same exact thing as the 2.0. The only difference is it has the EFCI badging on yop. Let me know if you want it, if not someone else will buy it.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by Javageek on 02-01-2005
I need a TPS screw and washer. Do you have one available?</div>
Yes!!! I actually have two. $25 shipped for each. Please let me know if you want it because other people have inquired.
TibMinn you have dibs on the other.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by fonseca on 02-05-2005
Hey TC, I still need:
-Tailgate lift supports #81770-27011 if you have 'em.
-Metal ashtray insert.
-the two bolts or whatever it is that holds the rear metal loops/hooks on the underside of the seat cushion to the car. They should have a bolt each, and let the loops slip through them or something.
-I need two bolts that connect a seat back to the seat brackets. There are only two bolts on each seat, those are the ones. Mine aren't the oem ones on one seat and they're rusty. I can get a photo of the above two items if you need it.
-I need a few other exterior bolts, like three of these:
Four of these:
These three:
And four covers to these:
And two (I think) of whatever goes here:
And maybe six of the metal clips that hold the grills:
I"m not in a hurry for this stuff, if you need to wait until it's warmer. Except for the lift supports. I'm still actively trying to locate a set that friggin' works. I have now purchased three sets and two didn't fit and the third did but wasn't charged.
Update: If it's the same between gens I'll take the pocket from the driver's side door panel. It unscrews from the back.
</div>
I already responded to you once, but you never answered me. I belive the lifters are the same model number. I have to double check still.
Get me pictures of the bolts you need from the seats, because I have a whole bunch of bolts and I have no idea which go where.
I dont have the ashtray insert or the grill clips, or the door handle screw covers.
I do have the door pockets and those other bolts though.
Please let me know if you want everything and I'll get you a price.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by JonGTR on 02-17-2005
Can you get me the gas pedal and just the plastic bucket from the glovebox?</div>
Yes sir...I have both. How's $25 shipped?
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by 97blacktib on 02-19-2005
would you have the AC from your old tiburon and the driver's side window regulator?</div>
The AC condensor? Or which pieces would you need? I do have the regulator.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by a_gut on 02-19-2005
How much a rear passenger side seat belt buckle (black interior)? Mine folds down the wrong way</div>
I would only be able to sell you the entire seat belt I could do $25 shipped for it. Let me know.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by zhiryst on 02-23-2005
Quote:
Originally Posted by Tibbychick
I might have an extra clock, I'll have to look. I do have the dome light however.
SWEET. Can you hold on to those for a week? I'll be going with Jay to pick up the RD chassis, so I'll buy them off you then smile.gif</div>
Hey, well since you guys arent picking up the car would you still want the dome light? I dont have the clock. Let me know.
EVERYONE please tell me whether you want these parts or not. If I dont get a response within a few days, then I will offer the parts to other people.
Thanks.
Patreezy, did you need the master cylinders? Or were you just telling me how to get them out? Because tanc needs both, and I owe him for the 02 sensor. Im confused, lol.
Old Mar 8, 2005 | 03:45 PM
  #164
javageek's Avatar
I just need the TPS screw and washer, not a TPS. I also need the plastic part that the heater cable connects to, under the dash.
Old Mar 8, 2005 | 03:53 PM
  #165
'treezy's Avatar
<div class='quotetop'>QUOTE (Tibbychick)</div><div class='quotemain'>Patreezy, did you need the master cylinders? Or were you just telling me how to get them out? Because tanc needs both, and I owe him for the 02 sensor. Im confused, lol.</div>
YES, I do! Please include (although you said you already shipped it this weekend....so......???)
...and YOU'RE confused!!!??????
what is going on tibbychick? I don't wanna clutter you thread with my questions on my shipment so just check your pm's please. ASAP! I'm VERY confused. Why is my order for sale IN HERE?????
Old Mar 8, 2005 | 03:57 PM
  #166
tibu971.8L's Avatar
Cools I'm happy then.
  #167
Tibbychick's Avatar
dude, check your PM. Ive got everything under control.
<div class='quotetop'>QUOTE </div><div class='quotemain'> I just need the TPS screw and washer, not a TPS. I also need the plastic part that the heater cable connects to, under the dash.</div>
Ohhhh ok. Hmm alright howabout $10 to cover shipping and a box...I'll send you the whole cable including the plastic piece.
Old Mar 8, 2005 | 04:02 PM
  #168
tanc's Avatar
Vehicle: 1997 Tiburon
Okay tc this is an update. I don't need the clutch master cylinder or the brake master cylinder. I've pin pointed the problem. I need the "clutch release cylinder" which is located right above the clutch housing. Don't get it confused with the master clutch pump because thats not it. Is 15$ that you still have of mine okay for that? It's not a big part. And when will you ship.
How much for the head? Condition? Miles?
Also curious if you have 1.8 pistons? If so miles?
Old Mar 8, 2005 | 05:31 PM
  #169
TC, have you sent my box yet? If not, there is one other thing I need. 1 seat mounting bolt. Just one.
Also, you did include some of those plastic button thigns we talked about right?
Old Mar 8, 2005 | 08:53 PM
  #170
Tibbychick's Avatar
<div class='quotetop'>QUOTE (tanc)</div><div class='quotemain'>Okay tc this is an update. I don't need the clutch master cylinder or the brake master cylinder. I've pin pointed the problem. I need the "clutch release cylinder" which is located right above the clutch housing. Don't get it confused with the master clutch pump because thats not it. Is 15$ that you still have of mine okay for that? It's not a big part. And when will you ship.
Also curious if you have 1.8 pistons? If so miles?</div>
Hmmm ok that should be fine. I just have to figure out where it is. Got a pic by any chance?
About the head:
<div class='quotetop'>QUOTE </div><div class='quotemain'>1.8 Head minus intake cam: Its got 103k miles on it, but me and my boyfriend inspected it closely and it is in very good condition. Minimal wear and no visible corrosion or anything. $300 Local pick up preffered. I may be willing to ship it but its heavy so I'll have to see.</div>
I do have pistons but my boyfriends gotta see if he can get them out. They also have 103k miles but we both looked at them and they looked fine. Even the head gasket was in excellent condition.
REDZ, nope today it was blizzarding out so I havent left the house. I can throw that bolt in...and the plastic caps, you meant the screw covers, right??
