Fs: Tire Pressure Monitor System, Rd2 D/s Headlight
Old Apr 16, 2007 | 04:49 AM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
I bought a tire pressure monitoring system for my Tib which I will have installed next month when I put my new tires on. I'm thinking of putting the display unit above my rearview mirror. At the same time I decided to purchase 5 more and try to sell them here and make just enough off of them to pay for the one I'm going to put on my Tib. Anyways, onto the item itself.
VALET Model: TPMS400 / P/N 9104
Tire Pressure Monitoring System...
Features:
Measures pressure & temperature in all 4 tires
Pre-programmed sensors supplied in sleep mode to preserve battery life
Fast leakage warning
Adjustable pressure level settings
Tire rotation "on-screen"
Easy installation
High temperature warning
On board diagnostics, self checks after each vehicle start
Configurable display settins (PSI, Bar, �F, �C)
Early fault detection
Not dependant on reference value, reads actual conditions
Able to detect multiple leakages at one time
Suitable for run-flat tires
Suitable for spare tire
Much more precise than indirect systems
Works while stationary and moving
Wide operational band
Includes:
4 pre-programmed wheel sensors
1 Receiver module
2 Button LCD display with bracket
Flexible antenna
Power harness, connectors and fuse
Double sided tape and cable ties
Installation and users manual
Pictures:
Just so you can see the size of the display unit that goes in your car I put my key on it.
Here is a picture of the box, display unit, installation/users manual, and the unit that hides under your seat or wherever you want to put it.
Price: $135 Shipped in the U.S. (5 sets)
Also, I have a driverside headlight for an RD2. It's still in good shape. Just a few normal wear and tear minor scratches.
Price: $75 + Shipping
Price matching...
http://froogle.google.com/froogle?q=valet+...=Search+Froogle
http://shopping.yahoo.com/search;_ylt=A0oG...amp;fr2=tab-web
http://search.ebay.com/search/search.dll?f...&category0=
Old Apr 16, 2007 | 06:45 AM
Mr. Muffin's Avatar
Vehicle: 01/hyundai/tiburon
so the sensors just go on ur valve stems?
do u know how much they weigh, weight on ur drivetrain matters alot moe then added weight in ur car... (although there probibly to light to make a difference)
Old Apr 16, 2007 | 03:00 PM
Tiburonmoo's Avatar
Actually, it replaces your valve stem completely. I'll take a picture of one of the sensors. I can go home tonight and weight them for you. They are pretty light. I'll post the weight of the sensors tonight for you.
Old Apr 16, 2007 | 03:36 PM
viper2x21's Avatar
if nobody buys the headlight, i need the cap that covers the h7 bulb, again if nobody buys it, could we work something out?
Old Apr 16, 2007 | 04:03 PM
Tiburonmoo's Avatar
Sure, we can work out something. I'll give it a week to try and sell.
Old Apr 16, 2007 | 04:13 PM
peter_2150's Avatar
I would really like to see the tire pressure monitoring system installed.
Old Apr 17, 2007 | 05:29 AM
Tiburonmoo's Avatar
Ok, it should be installed on Saturday if they get my tires in by then. The only things you would see would be the display unit and I guess the replacement valvestems. I'll take a picture for you though not a problem at all.
Edit: I tried to weigh the sensor on my scale and it doesn't register at all. I only have a regular full sized scale. It's a digital one and breaks your weight down by .1 lbs and nothing comes up. Going by my "handscale" it's about the weight of 2 refrigerator magnets. smile.gif
Here's a picture of the sensor that goes inside your tire and replaces your valvestem.
Edit again:Meant to have this in the original post.
Price matching...
Old Apr 21, 2007 | 09:54 PM
Tiburonmoo's Avatar
Bump for headlight.
Didn't get sensors/tires installed this weekend b/c of lack of funds from helping my g/f with moving deposits. Maybe next weekend. It will be done soon because front pass. tire needs replacing soon.
Old Apr 21, 2007 | 10:01 PM
Black01Tibby's Avatar
I may need the headlight if I can't figure out what is wrong with mine. Give me a couple of days to try and figure mine out.
Old Apr 21, 2007 | 10:31 PM
Tiburonmoo's Avatar
I'd love for you to buy it but if your having any kind of lighting issues(i.e. lights not working) then this wouldn't help. Like Ericy said in your other post it's probably your fuse. That would sound correct to me anyways.
