rpms on a dyno? true or false
Old Feb 2, 2005 | 09:56 PM
bryce804's Avatar
Default rpms on a dyno? true or false
i was looking at a dyno on an exhaust with a friend. and the power/torque crossed around 4k. he immediatly said its not a good dyno and to keep looking. he said that all dynos that are accurate the horsepower/torque will cross at 5200 rpm. is that true?
Old Feb 2, 2005 | 10:24 PM
hamhead's Avatar
Generally speaking, yes they cross around that area. That shows that its fairly accurate. Torque is a formula directly related to HP.
Old Feb 2, 2005 | 11:07 PM
a_gut's Avatar
I imagine this also depends on the camshafts, as there is only 1 camshaft profile best for a specific rpm, and not every car has variable valve timing, so I can see peak power and torque dropping off before before 5200rpm.
Old Feb 3, 2005 | 11:35 AM
hamhead's Avatar
Torque = HP / RPM plus some other crazy number thingies. Its not necessarily at peak power and torque where they cross. You could have an engine that the torque and HP lines cross well below peak. If you want to see some good dynos, go to AEM's website (aempower.com) and look at all their dynos. They all cross in the 5200RPM area.
Old Feb 5, 2005 | 11:03 AM
turbulence's Avatar
as far as i know, torque and hp will always cross at 5252. if you look at the hp equation (torque*rpms)/5252 = hp, you'll see how that works.
Old Feb 5, 2005 | 11:52 AM
hamhead's Avatar
Thank you! Gah I knew that formula but I couldn't think of it. Mucho props...
Old Feb 6, 2005 | 12:21 PM
bryce804's Avatar
so if the rpms dont really match at 5200 it is probally not a correct dyno? and i shouldn't trust dyno sheets unless they match.
Old Feb 6, 2005 | 01:01 PM
hamhead's Avatar
Yeah, the dyno is bad. I don't really see how it wouldn't cross @ 5200 unless it was like... faked or something.
Old Feb 6, 2005 | 07:11 PM
bryce804's Avatar
me either, guess this proves me wrong. ( had a small bet with a friend) thanks guys.
