Putting WD-40 on tires
Old Mar 28, 2013 | 12:02 PM
geo's Avatar
geo
Default Putting WD-40 on tires
I have heard some people say that if you have a set of track tires that have hardened up, you can spray them down with WD-40 and it will soften them back up. Any mythbusters put this to the test? Does it really work?
Old Mar 28, 2013 | 07:35 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
DON'T. Unless you want to throw that set away immediately after. There is a particular compound, I forget what it is, where you need to paint it on the tyres, glad-wrap them, then sit the set in a cool place for about a week. See if you can find out what it is, its a huge cash(and time) saver.
Old Mar 28, 2013 | 09:45 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
wd-40 pretty much does the same thing tire dressing does when applied, they eat and degrade the rubber, accelerates dry-rottng, and develops large areas of cracking
rainwater strips the tire dressing or wd-40 off and leaves the tire dried out.
if you want to take care of your tires or prolong the rubber compound from dry-rotting, clean them with mild soap and water, and keep away from extreme heat.
dry-rotted tires caused by tire dressing or any silly slicky oily chemical will also void any tire warranty.
Old Mar 31, 2013 | 04:18 PM
wheel_of_steel's Avatar
I've heard of soaking burnout tyres in diesel to make more smoke, but I haven't tested it myself. I very much doubt that it would help the tyres out.
Old Apr 1, 2013 | 07:38 AM
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
About 25 years ago my father in law used to use oil of wintergreen on the tyres of his sons competition go-kart, i guess it's still around some call it tyre prep?
http://www.hdmworld.com/tirepreps.htm
