Is it possible to hit 14s on all motor
No turbo, no nitrous, all motor only. Can you hit 14's easily with an RD?
HAHAHAHAHAHAHAHA no
He didn't say with full interior and street tires.
Make it very light Get the suspension right Slicks Add all the N/a mods Why not? |
Easily? No. However, with enough money... I'll hit 8's, all motor.
I think it's very possible. I thought there was a member or two that did. Mid-15's is easily accomplishable with minor bolt-ons, a few weight reductions, and good tires.
Edit: A quick search looking in the stickies shows that Tdonnell did: https://www.hyundaiaftermarket.org/f...ost__p__425041 |
I'm sure I will be able to do it. Can't wait for Spring to come :D
What about a stroker kit? Get the engine to a 2.2 or 2.4, with every single bolt on, slicks, suspension mods and no interior...you should be able to do it ok. Not low 14's or even mid. More like 14.9 to 14.7 at best.
For 14’ you need power to weight ratio around 4,5kg/1KS and up to you is how you will accomplish that :)
If you strip everything from the car I think that you will be around 1050kg but you will need at least 200HP for low 14’ |
Originally Posted by MaverickLC
(Post 714081)
Everything under 1100kg is not easy to get and you can forget about the interior ;)
