auto x inspection ?
hey guys, Im looking into getting into the Auto-X thing, however i have a ? to ask.. When you got through the inspection, what exactly do they check for in order for you to perform? I would like to see if my car is up to standard for me to go ahead and do it.. your help would be greatly appreciated thanks..
Take out anything that's not bolted down. Floor mats, etc.
Here are the instructions from the chief of tech's checklist for the NWR SCCA: <div class='quotetop'>QUOTE </div><div class='quotemain'>No oil, water, or fuel leaks Fan belt in good condition and tight enough Battery secured Wiring in good condition Throttle springs safe and functioning properly No excessive grease accumulation Exhaust system leak-free and in good condition Shock absorbers in serviceable condition Wheel bearings tight Steering gear tight Acceptable tire condition (enough tread, no cord showing) Hub caps and wheel trims removed Tight lug nuts All loose objects removed from interior and trunk Adequate seat belts Brake pedal height and firmness Make sure helmet is rated Snell 95 or higher Make sure number and class are visible on both sides of the car (this is required for accurate timing)</div> |
