Other Hyundai Models Forum All Hyundai Forum. Discuss all other Hyundai models here that not listed anywhere else, such as the Hyundai Pony and Hyundai Scoupe!
*urgent New job risks* Will a alpha 1.3 Getz engine work with 2002 Alpha Accent gearbox ????
Old Aug 5, 2013 | 11:25 AM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default *urgent New job risks* Will a alpha 1.3 Getz engine work with 2002 Alpha Accent gearbox ????
I fitted a Stock 215mm Getz Clutch kit too my Hyundai accent with stock gearbox using a accent release bearing
after about 300 miles my release bearing started making a noise and 10 miles later smoking and i heard a nice clunk pressure plate sound. (car still drives fine for sort period) (10-40Seconds)
2002 Accent engine Used 1.3 (185mm Clutch)
2003 Getz engine Used 1.3 (215mm Clutch)
If i fit a full Getz clutch kit and not use the accent release bearing inc new Bearing should accent gearbox be ok ?
THANKS
Old Aug 5, 2013 | 12:36 PM
gonna be hard to answer this question mang. we dont have the getz here in the states
Old Aug 5, 2013 | 06:56 PM
wheel_of_steel's Avatar
Not sure, but I used an LC clutch disc and pressure plate on my X3 and it could not disengage enough to get the car into gear.
I'd pull the transmission off and see what's actually damaged first. It might be a fried disc, might just be a bad throw out bearing that you disturbed when you took it all apart.
