welder
Old Jun 24, 2011 | 10:30 PM
Default welder
opinions on a good beginner welder?
basic car sh*t really, wanna be able to weld stuff like strut bars(3/8 thickish i guess), has to be good for a noob like myself, be simple to use, and do strong welds in case i decide to do weird mods like suspension work or make my own roll cage
i plan on stickin with brand name, just donno if i should go mig or stick
Old Jun 24, 2011 | 10:32 PM
03-accent-03's Avatar
Vehicle: 03 Hyundai Accent
MIG will give you MUCH better welds. Once you get the technique down, you'll be great.
Old Jun 25, 2011 | 02:13 AM
supercow's Avatar
I got a stick welder and wish I got a mig.
Old Jun 25, 2011 | 03:28 AM
Loneshark's Avatar
Vehicle: 2000 Tiburon
get something like this.
http://www.sears.com/shc/s/p_10153_1...u=00920580000P
Old Jun 25, 2011 | 06:51 AM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
you want a mig for general use but you'll want a tig for a roll cage-...
lincoln, miller, esab, or hobart are the brands i would trust and parts are pretty common for as well.
pay attention to the duty cycle of the machine!
Old Jun 25, 2011 | 07:40 AM
Hmm I've never heard of people having to tig mild steel before for a cage
Even the rule book says MIG is fine
Old Jun 25, 2011 | 10:44 AM
JonGTR's Avatar
Lincoln is a reliable brand and what I have. Cost me about $380 shipped. Its a mig and has welded everything I've needed so far but I had to settle for a 120v due to the house I used to live in. Get a 220 if u have an available outlet for it. I've been using fluxcored wire without the hassle of hooking up gas. If I need aluminum done, or something that must look perfect, then I take it to someone with a tig. Hasn't happened much.
Old Jun 25, 2011 | 10:54 AM
01steve's Avatar
you could use mig on a roll cage but you have to be a bit more carefull as to where the sparks/spatter will land-... they will stick to glass!
with tig you wouldn't have to tear as much of the car apart to put in a cage as there isn't any spatter in that welding process. also if you're looking to do a chromoly cage, tig is definatly the way to go!
