tranny swap quirk
Old Mar 21, 2003 | 02:09 PM
turbulence's Avatar
Default tranny swap quirk
ok, it's been almost a year since i did the auto to manual swap, but this is kinda interesting, and i just thought to post it now. before kevo figured out which wires needed to be spliced to make the car start, when we would turn the ignition on, the driver's window would go down. just something i thought i'd share with the rest of you. after the window was down, if we turned the key, the window wouldn't go up (just thought i'd throw that in there). for some reason, i just made the window go down. hmm
Old Mar 21, 2003 | 05:34 PM
FlyRyde's Avatar
Crazy. When we do the same in mine, the rear right tail light comes on (with the headlights on) the right turn signal only works and one high beam is matched up with one low beam. hehe still some wiring to mess with. I switched the whole wiring harness from a 2nd gen into my 1st though.
