Need network help!!
Ok I'm running 4 computers on a Netgear MR814v2 Wireless router connected to roadrunner. Yesterday, it decided to block me from this site. I logged into the router and double checked no sites were blocked etc... So I have no idea why I cant get onto this site with that router. I updated the router's firmware to the latest 5.3 but nothing is working.... HELP!!!!
#1 how are you connected now?
#2 can any of the computers get to this site?
#3 have you rebooted the router/modem?
edit: don't rule out the possiblility of java playing a little joke on yah and blocking your ip laugh.gif
QUOTE (Supercow)
1. using a different router
2. no computers on the network can get on, i know its the router becuase I replaced it and now im on the site
3. yes i've tried that several times
do all other sites work fine with the other modem? to say the least this is rather odd. there are ways in most routers to block sites but if you've upgrade firmware and reset none of that would be there.
when using the router that is having problems ping rdtiburon.com
aparently there has been dns issues, don't know why they would hang that long though, could be stored in the router depending on model.
anyways the ip should be 64.5.52.94
you ping by going to start>run>type "command" hit enter>type ping rdtiburon.com then compare ip
also try going to that ip rather than to the normal rdtiburon.com url
