High/low Beam Headlights?
Old Jan 12, 2008 | 08:46 AM
Larrs's Avatar
So I keep seeing different setups on head lights.On some Tibs I see the inside head lamps used as low beam lights,and on other Tibs I see the outside lights are used.Can these be swapped,or did this come from Hyundai on different models?
Old Jan 12, 2008 | 08:53 AM
on RD2, the inside are high beam reflectors. THe outsides are low beam projectors. You cannot swap them.
Old Jan 12, 2008 | 09:02 AM
Larrs's Avatar
That's what I thought!I'll try to pay attention to why I've been noticing the two different setups.I'm sure I've seen this on more than a few different Tibs.
Old Jan 13, 2008 | 09:44 AM
rallyman's Avatar
Are you sure you aren't just seeing people driving around with only their daytime running lights on at night? Then only the inside lights would be lit up.
Old Jan 13, 2008 | 01:06 PM
do Canadian tibs have daytime running lights?
Old Jan 13, 2008 | 01:27 PM
Larrs's Avatar
Nope daytime lights are only the parking/turn lights and the positioning light.I cant seem to find a car with the inside lights on now........?I will post cars when I see them.Larrs
Old Jan 13, 2008 | 03:10 PM
They don't make them like that my man. If you've seen that, it's straight up custom or a backwards install.
Old Jan 13, 2008 | 04:12 PM
so.. why is this in grips and complaints?
Old Jan 14, 2008 | 07:20 AM
rallyman's Avatar
QUOTE (majikTib @ Jan 13 2008, 03:06 PM)
Yes, it has been mandatory for all cars sold in Canada to have daytime running lights since 1990.
QUOTE (Larrs @ Jan 13 2008, 03:27 PM)
Actually that is wrong. The daytime running lights are on the high beams. Hyundai chose to also have all the parking/marker lights come on as well but the DRL's are the high beams operating at a low intensity. If yours do not operate this way then there is something wrong with the unit that controls your DRL's, your high beam bulbs are burned out or your car is not a Canadian model.
