Fire Wall Help
Old Sep 23, 2002 | 10:28 AM
D4Damager's Avatar
Default Fire Wall Help
I pulled a plastic Grommit from my firewall to feel a wire through to power my neon light and the wire isnt coming out ANYWHERE, ive put about 10 feet through and nothing. Under the dash there is a big plastic piece, looks like it holds the ECU. Any help?
Old Sep 23, 2002 | 11:48 AM
tango's Avatar
Might help if you gave a little more info...like which grommet you pulled! One ide when doing these things is to locate the grommet from INSIDE first. Then find where the cable comes out in the engine bay.
Old Sep 23, 2002 | 04:17 PM
D4Damager's Avatar
there are 2 grommets directly behind the air intake IN the engine. I pulled the one closest to the passenger door.
BUT underneith my dash is a huge place piece, making it nearly impossible to see anything. I hooked up a light at night to see where it would shine through but i had no luck frown
