Cleaning patching - 9mm
Old Feb 22, 2010 | 10:05 AM
grind's Avatar
Vehicle: Hyundai Accent
Default Cleaning patching - 9mm
Cheap place to buy some good quality ones?
Those of you using bore snakes, do you use the bore snake to replace the rod and patches to clean the barrel? How many cleanings are you guys getting out of boresnakes?
Old Feb 22, 2010 | 10:09 AM
I've been using bore snakes unless the crud is really thick. I've used my .45 bore snake probably 50 times and it still seems fine.
I get most of my cleaning supplies from Cabela's. I got most of the bore snakes from Sportsman's Warehouse.
Old Feb 23, 2010 | 07:09 AM
grind's Avatar
