Zex install
Zex install
I'm instalkling the zex kit tomorrow and just triple checking the instructions. Step 6 says to connect the two rubber hoses to the fuel pressure regulator and an unused vacuum fitting coming off of the intake manifold.
Anyone have a pic of these connections?
Just want to make sure I do everything right the first time!
yes, your site has been very helpfull, thank you for putting that information up. The only connections you don't show are the ones using the rubber hoses that came with the kit. If you could post those pics I would greatly appreciate it, thanks!
Also I do have a voltage meter, its analog but I can set it to a scale of 1-15 so I should get a fairly accurate reading of the 4 volt area.
Ok pics won't show you, the rubber hoses are for the fuel regulator, it's on the far left of the intake manifold, there is a little grey hose that connects from there to the regulator on the end of the fuel rail. Pull off the grey hose, One hose goes from the Zex box to where the grey hose was on the intake manifold, the other goes to the regulator, which ones are marked on the zex box ( intake, fuel I think was the label ), becasuse of the distance a pic won't show you, you'll see 2 hoses from the zex box and the the others in another photo but I'll take a pic to show you the regulator and manifold connections.
