Wiring a Zex Kit
Installing a Wet kit on the tib, the Nitrous Mgmt Unit has a White Wire that says "To Throttle Position sensor voltage output wire" WTF is this? Any help would be great, any pictures would be better.
Edit
This is for the 4 cylinder beta engine.
Edit
The throttle position sensor is on the Throttle Body. I think it goes to the middle wire. You can search on the forums for more detail on my DIY install nitrous oxide in a tiburon, for my 2001 tiburon. I believe it was the middle wire on my setup.
The throttle position sensor activates the nitrous when you are at full throttle. It is calibrated to your pedal during the Zex calibration sequence.
