what is need to run 100 shot of nitrous
my nx direct port only came with jets small enought to run 100 shot...so i fiugred i put thse in tere and see what i need to do to support this
You mean smaller jets. Not larger nozzles...
Just give NX a call on Tues and ask for the correct jet sizes for 75hp, which are usually found in the motorcycle direct-port kit. I don't have all the specs in front of me, sorry.
To really use a 100hp shot, you need a progressive controller, better clutch and either slicks or drag radials. A better exhaust (at least 2.5") would help a bunch as well, if you have a header that would be nice too.
A friend of mime ran 12.4@108 a couple of weeks ago, putting down about 270hp from a single nozzle kit and 2.4L DOHC swap in a 2560lbs car. On slicks, btw (20x8x14 MT's)
[ September 01, 2002, 01:37 PM: Message edited by: Anthony Thomas ]
Bringrice:
go on ebay and see if you can get larger nozzles, or even try the NX site
