Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
WET v.s. DRY
Old Jan 19, 2005 | 01:47 PM
injected's Avatar
Default WET v.s. DRY
--98 TIB--
wich will increase my power most ??
wich is the most safe 4 stock engin ??
wich is the cheapest ??
WET v.s. DRY
Old Jan 19, 2005 | 01:50 PM
mb1604's Avatar
ive seen about the same prices for both and i heard wet is better, but ive just heard that, i have no experience in using it
Old Jan 19, 2005 | 02:48 PM
javageek's Avatar
Wet is safest because it is putting in fuel as well. Dry would be the cheapest.
Old Jan 19, 2005 | 02:56 PM
JonGTR's Avatar
QUOTE (javageek)
They both put in extra fuel, just in different locations. The dry runs though the injectors by using the fuel regualtor. In theory they are both safe and provide the same amount of power (depending on the jets you use). But most problems come from dry kits and the regulator control.
Even though the kits come with easy instructions, try to learn exactly how nitrous and the kits work. That way you can take extra precautions, be able to maintain the kit, and troubleshoot if needed.
Installing a kit is easy, but knowing how to keep disasters from happening is a whole different step.
Old Jan 19, 2005 | 03:06 PM
BillyDee01Tib's Avatar
wet, me and my grandpa put a wet shot on his 4 banger ranger and it was what was recommended and works well. We like wet over dry, just my two cents.
Old Jan 19, 2005 | 03:24 PM
hamhead's Avatar
QUOTE (JonGTR)
Yep. Both dry and wet get more fuel in. If it didn't add fuel with a dry, you would lean to hell since your injecting the nitrous after the MAF/MAP. I think... I'm not a nitrous guru in any way. On a Tib, I wouldn't go over a 50 dry or a 75 wet on a stock engine.
Old Jan 19, 2005 | 09:15 PM
javageek's Avatar
Old Jan 19, 2005 | 10:10 PM
OdessitPashka's Avatar
QUOTE (javageek)
I never realized Dry kits injected fuel as well.......
Nitrous oxide is basically oxygen once it reaches certain temperature and you just add fuel and get more power out smile.gif
Old Jan 19, 2005 | 10:16 PM
hamhead's Avatar
Yep... the nitrogen atom kind of acts like a shield for the explosion. Pure oxygen = boom in engine. Just for giggles if you have air tools, spray regular air (not pure o2) up your intake. Revs should raise slightly. Essentially what forced induction does. I never really had much experience with nitrous except that I was looking at an intercooler kit for the GSX and learned how it all worked. smile.gif
Speak of the devil, this was my 500th post... so Nitrous Oxide is my title. LOL.
Old Jan 19, 2005 | 10:26 PM
QUOTE (hamhead)
my bad, I meant to say "boom, too lean"
