Turboron_99 |
04-20-2010 07:56 PM |
Well not running a bottle heater will not make you blow you motor lol, All it does is give you the ability to control the bottle pressure as you use nitrous, with out a bottle heater as you use the nitrous obviously the Psi in the bottle will drop, which if you are running a 50 or 60 shot, then obviously with presure drop you get less of a shot, with a bottle heater you can run the very last pound of nitrous out of the bottle and run that last pound out of the bottle at 900psi and still get the full effect of the 50 or 60 shot. So spend the extra 150 dollars and get a bottle heater. Zex has a really cool one, that has abuilt in regulator and doesnt need to have a huge ugly relay hanging around and doesnt need to have a attachment to the nitrous in line like most others do. Plus it is like 160 dollars! So buy one.
