NX kit buying?
NX kit buying?
i did a search and found that the item number for a nx kit was 80004efi posted by RED does this kit include every part that i will need to put this in my 97tib fx and make it work? i only want to run the least possible for now which is the 50shot then maybe the 75shot later i'm also going to get one of those automatic bottle opener another question with just running the 50shot direct port what should i change like the spark plugs and wires or could i just run with the stock ones thanks for ya time
The single fogger system is a generic "Import Kit". It will include everything you need to install it.
It is not a Direct Port system. You can not run a 50 shot on a direct port system b/c it would require too small of jets, which they don't make.
For plugs, do a search. It's everywhere.
