Nitrous and turbo question.
Well, we all know that at approx 280-290whp our MAF sensor will max out and will not let us gain anymore power, but would we have enough fuel to support lets say another 70shot of nitrous? The engine should of course be build to support that power, but what if it has new pistons and stuff, and you are maxing out your MAF s. and decide to spray, would that be possible?
looks like you just WANT to lean out and go boom... because i think that would happen. your MAF wouldnt extend the injector pulse width as needed for the extra air because its already max out, thus causing you to lean out, and you REALLY dont want to lean out with nitrous
well true, wet kits do spray fuel. im not sure how effective that little bit of extra fuel is when you are maxed out on your MAF because in a wet kit the fuel isnt evenly distributed into each cylinder so all you have to do is go lean in one cylinder and your engine is hosed. Direct port may worth though
hmmm, its kinda like 5th injector. many people were able to get it up to 13PSI, so it can't be that uneven. I just don't wanna deal with direct port.
And look, there is a bunch of people that have sprayed 60-70shots, and no one fried their pistons. If it was so bad then no one would be able to spray so much. I dont think the question is about how uneven is will be, the question is will the solenoid and the fuel lines give me enough fuel not to run lean?
cant remember what they are called but the thing you put in the shark nozzle that determines how much fuel or nitrous that is sprayed into the system, you could just put a big one on the fuel side... and try that but i dunno.. there is only 1 way to really find out smile.gif
more power too ya, id like to see you break 300whp with boost and nitrous, that what i know i can do it.
