Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Nitrous mounting location help
Old Aug 14, 2004 | 04:53 PM
javageek's Avatar
Default Re: Clutch question
I recently purchased a NX Wet System. I have the bottle mounted on the right side of my trunk with the nozzle towards the front like directed. I have the main nitrous line running along the right side through the interior. Where should I exit the vehicle with the line? Also, where should I mount the solenoids? I have a Nitrous, Fuel, and Purge solenoid. If you could post pics of your setup that would be awesome!
Old Aug 16, 2004 | 07:19 AM
JonGTR's Avatar
Default Re: high pitched sound (radio)
I wouldn't run it IN your car. I ran mine out the wheel well and along the rail where the fuel lines go. I ziptied the line to them. I then brought the line up between the firewall and the shock tower. I mounted one solenoid there, and the other on the firewall.
Old Aug 16, 2004 | 08:47 AM
Glock33's Avatar
Default Re: A few new engine shots after paint
here you go hahahaha
Old Aug 16, 2004 | 08:56 AM
Dweet's Avatar
Default Re: Nitrous mounting location help
http://www.rdtiburon.com/index.php?name=Fo...viewtopic&t=547
there ya go.... java
Old Aug 16, 2004 | 09:30 AM
Default Re: Guess I gutta start over...
Dweet, can you edit that post to just the link for your post in the DIY section?
Old Aug 16, 2004 | 10:18 AM
javageek's Avatar
Default Re: Iceman Billet Aluminum Throttle Bodies!
Wow! That's just about everything I needed. One question though, did you drill a hole through the firewall, or use an existing one. The only one I know if is directly behind the IM and it is packed with wires already.
Old Aug 16, 2004 | 10:27 AM
Default Re: My car and body kit
there is supposed to be a huge opening to the left of the clutch pedal between the passenger compartment and the fenderwell.
Old Aug 16, 2004 | 10:47 AM
Dweet's Avatar
Default Re: Tib = Suck
QUOTE (javageek)
The one with a bunch of wires is your wiring harness... Id stay away from that one. I drilled the hole myself. Im not scared of putting holes in the firewall. I had to drill another hole for my 4ga stereo wire
