Nitrous
ive finally decided what im going with. I wanted a turbo badly.... but cant seem to find one in my budget range... so ive decided to get a nitrous kit at my local racing store for around $600.00 w/ install.
Has anyone ever had any problems with engine blow outs?
although you want to have a quality brand its more of the size of the shot and the route of introducing the Nitrous that factors into whether your engine will blow. a wet shot is safer than a dry shot because it adds fuel. 50 is said to be the highest you would want to go stock w. dry , and with wet you can go higher to about ~100 shot. The higher the shot the more dangerous it becomes. if you are going to do nitrous you should know the ins and outs, even if your not doing the install. here is a very recent thread that might help out little more
http://www.rdtiburon.com/forum/showthread....ht=nitrous+shot
since you did want a brand i guess NOS is supposed to suck and NX (nitrous express) is recomended here usually
hope this helps mang
ok, then let me refraise the question...
what is the highest shot you could use with a DPI kit with all stock internals and stock fuel injectors? And would you guys recommend the NX kit? Simplicity of install of a DPI kit (any harder than the nozzle kit?)
thanks!
thanks!
i read some were on here that you want to go with stage 1 colder spark plugs if you go with a 50 shot and stage 2 colder if a 100 shot.
about the fuel unpgrade. i thought it would be better to upgrade the pump and injectors?
