$1,100 for a nitrous kit?
Vehicle: 1998 Tiburon
Anybody think this is pretty excessive and over the top with pricing? http://www.designengineering.com/cat...threat-systems
Ny-Trex is proud to introduce the next phase of nitrous innovation, the Triple-Threat™ wet nitrous system. This system combines all three valve functions: Purge, N20 and fuel in one easy to install component. The Triple-Threat™ is a precision machined billet body with three integral solenoid valves with Volt-Trap coils for a dependable, clean, all-in-one nitrous system.
Ny-Trex nitrous systems use only the highest quality materials and components to produce the best looking, best performing and most reliable wet system around. Ny-Trex exclusive Triple-Threat™ systems have been thoroughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible.
Complete Systems Include:
10 lb Wet-Black powder coated bottle
Liquid Filled Bottle Gauge
Fuel Pressure Safety Switch
Complete Purge System with V-Spray
Chrome 660 Hi-Flo valve with gauge port
Braided stainless N2O feed line w/Teflon core
22”x-3 braided stainless nozzle lines, 1 blue, 1 red
T-Rex Nozzle & adapter (up to 300+HP)
Adjustable HP jetting
15A WOT micro switch
Quick-Clamp stainless bottle brackets
Mounting hardware, brackets, bolts, screws, clamps, ties
Electrical components, wire connectors, relays, switches
Drill & tap, fittings, sealant
Triple-Threat™ Valve w/Lifetime Warranty
Special Features
Exclusive T-Rex Nozzle with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering as low as 35 HP.
Solenoid valves are made with Volt-Trap coils for stronger, more effi cient power, allows for larger orifice, more flow and works with as low as 9 volts.
Plungers are made of high grade alloy with greater
tolerances to prevent sticking. The N2O seal is Teflon and a special Viton seal is used for fuel.
Dual Taper Jets provide a consistent flow of nitrous and fuel and come in a large array of sizes.
Easy install components such as well nuts to install bottle topside, drill bit and tap for fuel connection, Tefl on sealant and easy install Quick-Guide.
Special Features
i agree that price is steep as hell.. comprehensive as poop, but expensive for nitrous that you have to refill..
for someone with a built supercharged v8, needing extra easy power, this would be a good addition.. for a 4-cylinder, you could piece together REAL boost for not much more and never have to worry about a bottle fill-up.. would have power all the time, not just when the bottle is open or not empty.
That is a rip off!
1. You still need a DownTube to vent the bottle out side the car if you ever plan on racing at any kind of NHRA track that you have to get inspected by tech!
About 100 dollars for a downtube kit
2. You are going to want some kind of bottle heater.
They can range from 150-300 Dollars.
Only thing i can tell you is check out Turbosocks site, Get a begginers turbo kits, you will be much happier with the power you get and it is alwasy there, you dont have to check paying to fill it up, or find a place to fill it up!
I agree. You can get a ZEX base system for $400 and add on all the acessories for an extra $300... maybe you will spend $800-900 on a ZEX and get everything in that package plus a bottle heater, safety blow-down, and a bottle gauge. That's a basic kit for way more than it's worth.
just noticed what makes it a "Tripple Threat"
It's a tripple threat because it's a wet-shot and it has a purge.
....the Triple-Threat™ wet nitrous system. This system combines all three valve functions: Purge, N20 and fuel in one easy to install component.
Vehicle: '14 Ford F-150
I installed a $6000 nitrous kit in a C6 Vette. It had a separate fuel res for C16, fully progressive computer control, dual bottles with remote openers and bottle warmers. The nicer the kit, the higher the price.
