Wiring guide for stock HU
Ok while searching google I found a topic here for this, and it's what I already have:
Front speakers
LF(+) - B/R
LF(-) - W/R
RF(+) R/Lb
RF(-) R/Y
Rear Speakers
LR(+) - Br/R
LR(-) B/R
RR(+) B/Lb
RR(-) W/Lb
12v switchable acc B/W
12v Constant R/Y
Illumination (+) G/W
Illumination (-) G/B
Ground – Black (2.0g wire)
I don't know what all the letters stand for. Like theres 4 'R's but theres only 1 red wire.
Front speakers
LF(+) - B/R
LF(-) - W/R
RF(+) R/Lb
RF(-) R/Y
Rear Speakers
LR(+) - Br/R
LR(-) B/R
RR(+) B/Lb
RR(-) W/Lb
12v Constant R/Y
That is a description of the pinouts from the factory radio. You can use that, but I would suggest buying an aftermarket wiring harness. It plugs into the factory plug and you can solder / tube connect the radio's harness to that one. They are pretty good about matching colors for you.
They should be color coded, no? Double check with the above pinout, but they usually come where you can just connect the like colors.
BTW it appears that the pinout pic is upside down compared to the radio... look at where the fuse is on the sample pic and go accordingly.
<div class='quotetop'>QUOTE (bluetibbay)</div><div class='quotemain'>W00t I wouldn't of done it without that pic, thanks a lot laugh.gif</div>
NP mang wink1.gif you can thank Tibby01 for burning webtech in my mind tongue.gif
