Welcome To The Forums: 01bLUEsHARK
Old Jan 21, 2010 | 10:55 AM
RD Greeter's Avatar
Member Name: 01bLUEsHARK
Registered on: Jan 21 2010, 01:55 PM
Profile: http://www.rdtiburon.com/index.php?showuser=10075
01bLUEsHARK,
Hi, my name is ____.
I'm from ______.
I drive a ______ _____.
__
____
_
_____
Old Jan 21, 2010 | 11:24 AM
01BlueShark's Avatar
Hello everyone, glad to be a part of the community
EZ
I have an 01 Tibby and looking forward to your help with mods, BTW, My 01 Tibby had a little hesitation this morning (after driving 50 miles to work this morning), the car felt a little sluggish after the got to work. The check engine light has come on. I figured it was the plugs, given the way the car was reacting to the acceleration. I've changed the plugs from NGK (old 1 1/2 year old) to Denso U-Groove. The problem was solved, however, the check engine light is still on. Can anyone assist me as to where the check engine light switch is located, or, how would I go about resetting the check engine light.
Old Jan 21, 2010 | 01:06 PM
I can help.
First, you should read the post above yours, and then do what it says. Then use the search function to see if what you are wanting to ask is already covered. If it is, within reason, append to that thread. If not, then find the appropriate subforum for your vehicle questions and post them in there.
