new here but not to the scene
Old Dec 14, 2010 | 09:51 AM
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
Default new here but not to the scene
Hi everyone, I have the same screen name as I do at NT.com and EXD.com, some may know me and my vehicle and some may not so here is the low down on me and my Tib.
ME:
first Hyundai purchased 2002 Elantra GT...thus the screen name slow 2K2GT (cause it was slow)
29 years old
Canadian Military - Occupation: Infantry
Deployed three times, once to Bosnia, twice to Afghanistan...returned from there about a month ago.
Current car - 2003 Tiburon....
CAR:
Engine and Exhaust
-Garrett Ball Bearing GT3076r turbo
-Tial 38mm External Wastegate
-Maintec turbo manifold
-Ported and Polished Head
-Ferrea Titanium Dual Valve Springs
-Ferrea Titanium 1mm Oversize Valves
-268deg cams with 10mm lift
-Pauter connecting rods
-CP 8.8:1 pistons (.5 overbore)
-ARP head studs
-ARP main studs
-28x7x2.5 bar and plate intercooler
-2.25" intercooler piping
-HKS SSQV blow off valve
-3 layer silicone couplers with T-bolt clamps
-Koyo dual pass radiator
-Blitz high pressure rad cap
-OBX silicone radiator hoses
-Jattus turbo coolant kit
-Mishimoto oil cooler kit
-Siemens Deka 650cc injectors
-OBX lightweight water pump pulley
-Rside adjustable exhaust cam sprocket
-Rside adjustable intake cam gear
-Yaya front and rear polyurethane engine mounts
-Walbro 190lph fuel pump
-Progressive methanol injection kit
-NGK spark plug wires
-Polished aluminum oil catch can
-ARK V2 single 3" exhaust
-3" downpipe
-DEI titanium header wrap
-Valeo X-TRM clutch holding up to 450ft/lbs
-Valeo forged flywheel
-AtelierHP alternator relocation kit
-TWM Solid shifter bushings and linkage
Suspension and Handling
-ARK ST-P coilovers
-DC Sports front strut bar
-DC Sports rear strut bar
-Progress 22mm adjustable rear sway bar
-XD 23mm front sway bar
-Traction bars
-Eibach camber bolts
-Moog front and rear endlinks
Wheels, Tires and Brakes
-17x7 Tuscani OEM rims
-215/45 17 Bridgestone Potenza
-Kspec 12" BBK with 2 piston calipers
-Earls braided stainless steel lines
Lighting and Exterior
-FlyRyde carbon fiber hatch
-VIS Invader carbon fiber hood
-GT HID 8000K conversion kit
-Color Changing LED turn signals
-2005 F/L tail lights
-2005 F/L head lights
-2005 F/L front bumper
-M&S Carat front lip
-GT Tech type 2 sideskirts
-Metallic gas door
-Police Interceptor Badge
-LED license plate markers
-Custom 'Rat Rod' paint job
-Hella Supertone horns
Interior and Electronics
-AEM UEGO wideband controller
-AEM Digital volt gauge
-Autometer Phantom Boost, Oil Pressure, EGT Gauges
-Megasquirt 2 engine management system with sequential fuel injection
-Knocksense detection kit
-Momo Steering wheel adapter
-Ractive Steering Wheel
-Metallic Pedal Set with dead pedal
-TWM short shifter
-Kspec rubber shifter boot
-Odyssey PC1200 battery
-Odyssey HDW1200 battery tray
PICS: Car is away for season and a motor build and a full wire tuck.
Old Dec 14, 2010 | 10:52 AM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I cant wait to see this one done, I really liked the elantra.
Old Dec 14, 2010 | 12:56 PM
Lazyshot's Avatar
So sexy. I can't wait to see her finished. What kind of power are you aiming for? The setup looks like a good 300-350 whp car @ about 20 psi. The only thing that seems to be off is the fuel pump and fuel pressure regulator, but maybe you just forgot to list that. Walbro 190lph seems kinda small for the setup.
Old Dec 14, 2010 | 01:00 PM
Nice! Looking forward to seeing it all done!
