Hello I Feel At Home!
Old Feb 4, 2007 | 09:25 PM
welcome mang...
Old Feb 5, 2007 | 12:44 PM
gsasha1's Avatar
Vehicle: tiburon 1998
welcome rice-cooking-guy!
Old Feb 5, 2007 | 12:57 PM
what's up man, you have some high hopes, which is awesome. the tuning usually doesn't begin until you see occasions and them move along without mercy cool.gif . the P0442 code is from one of your sensors. if everything is stock, you want to go to the dealer and get one of the sensors replaced.
Old Feb 5, 2007 | 03:22 PM
^^ heck no, every sensor is easy to replace on our cars..
Your code is evaproative emissions control. Usually it means that you need a new fuel cap. I
f it were IAT or Power steering you'd throw another code with it. You can safely assume that the correct fuel (low grade) is being used. Engine coolant temp would throw a different code. replace your cap, and check for loose wires on your sensors. the evap canister might be the problem but not likely unless you did something to the gas tank or the canister itself. They don't go bad often.
<ul><LI class=ITEM>Improper tightening of fuel tank filler fuel cap<LI class=ITEM>Fuel vent valve failed<LI class=ITEM>Purge line or vapor line clogged<LI class=ITEM>Broken seal in fuel tank, purge line or vapor line<LI class=ITEM>Evaporative emission purge solenoid failed<LI class=ITEM>Evaporative emission ventilation solenoid failed<LI class=ITEM>Fuel tank pressure sensor failed<LI class=ITEM><strike>Engine coolant temperature sensor failed</strike><LI class=ITEM><strike>Intake air temperature sensor failed</strike><LI class=ITEM><strike>Power steering pressure switch failed.</strike>[*]<strike>Incorrect fuel (water, alcohol, etc. mixed) used</strike>[/list]Do you have any other codes?
