Clear Corner Install
Old Jan 11, 2005 | 10:57 AM
code's Avatar
Default Clear Corner Install
i know we just did this for the rearlights / etc
so what about the corner lights. any suggestions before i install mine,
(i usually mess up the easiest things)
Old Jan 11, 2005 | 11:06 AM
JalemX's Avatar
it is IMPOSSIBLE for anyone to mess this up!!!!
there's one screw per corner lense, unscrew that (corner of engine bay). slide out lights, slide in new ones screw. 3 minutes.
Old Jan 11, 2005 | 11:09 AM
UltraTibby's Avatar
I tried to slide mine out to just change the bulbs and they did not want to come out. I was about to take a hammer to the back of them so they would pop out but then decided it would be a good idea to have some clear corners to replace them with when I end up breaking them laugh.gif
Old Jan 11, 2005 | 11:14 AM
TibRacer01's Avatar
I also tried to remove mine to get the front bumper off but they would not come out. I ended up taking the bumper off with the corners still in place.
The 1st and 2nd gen may be a little different.
Old Jan 11, 2005 | 11:15 AM
JalemX's Avatar
can't remember for sure b/c i havent seen my car for like 5 months (sleeping 4 the winter) but you shouldnt have to slide the corners out to change the bulb.
Old Jan 11, 2005 | 11:16 AM
code's Avatar
whew, I hope i dont have to take the bumper off, imma be pissed then
Old Jan 11, 2005 | 11:21 AM
UltraTibby's Avatar
<div class='quotetop'>QUOTE (JalemX)</div><div class='quotemain'>can't remember for sure b/c i havent seen my car for like 5 months (sleeping 4 the winter) but you shouldnt have to slide the corners out to change the bulb.</div>
Didnt have too, it just would have been easier than taking out the battery.
Old Jan 11, 2005 | 11:58 AM
TibRacer01's Avatar
<div class='quotetop'>QUOTE (code)</div><div class='quotemain'>whew, I hope i dont have to take the bumper off, imma be pissed then</div>
I was taking the front bumper off and trying to get the corners out first. webtech tells you to remove the corners before you remove the bumper.
Old Jan 11, 2005 | 12:17 PM
Tibbychick's Avatar
wow.
This was about the easiest thing I have done to my car yet.
All you do is unscrew the screw, I know with first gens it holds the corner light to the headlight, and then either pull it out from the front with the help of a flat head, or push it out from behind. There's one pressure clip holding it to the headlight below the screw on the first gens. Might be a tad different with second gens.
Old Jan 11, 2005 | 01:33 PM
MrPSXplyr's Avatar
I just formally wrote up WITH PICS, my corner removal DIY. Check it out. Clear corner installation is just the reverse of my DIY.
http://www.rdtiburon.com/forum/showthread.php?t=4875
