300hp LC2 Accent
Old Jul 8, 2008 | 04:44 AM
Ryanator's Avatar
Vehicle: 2003 Hyundai Accent 22PSI Boost
Default 300hp LC2 Accent
Im an Aussie...and running the 1.6L Alpha motor DOHC...
Aries forged pistons and lightened rods
700 x 350 front mount
58mm Throttle body
T28 Ball bearing high flow turbo, T03 front housing
2.5 inch cooler piping
3 inch mandrel bent exhaust turbo back
32mm external wastegate
Plumb back BOV
Nitrided crankshaft
Hi compresion head gasket
Custom turbo manifold
EMS Stinger ECU
AEM Ignition Discharge Module
75HP Wet Nitrous Oxide System
22PSI BOOST!!! and revs out to 7250RPM
208.8HP at the wheels...
1)very bad tune at the moment
2)needs new spark plugs
3)needs new leads
4)needs injectors cleaned
5)no nitrous on that dyno run
300HP at the wheels when its all sorted out
about 345HP at the wheels with the nitrous setup
Adding CRYo2 intercooler sprayer chamber and sprayer bar
about 360HP at the wheels
12.86@179kmh No nitrous and no CRYo2
no slicks... 205x45 R16 blue streak streeters..
Check it out!!! http://www.hyperaustralia.com/forums/viewt...f=14&t=3624
Old Jul 8, 2008 | 05:23 AM
Daaaaammmnnnn......
Old Jul 8, 2008 | 08:19 AM
I would love to ride in that Accent!
Old Jul 8, 2008 | 08:47 AM
Thats with an Alpha too. Just imagine the power if it was Beta swapped with the same components. blink.gif
Old Jul 9, 2008 | 12:37 AM
Fintile's Avatar
<div class='quotetop'>QUOTE(Visionz @ Jul 8 2008, 07:47 AM) </div><div class='quotemain'>Thats with an Alpha too. Just imagine the power if it was Beta swapped with the same components. blink.gif</div>
How about NOT... I love that its the Alpha...too many people keep saying "Beta swap for real power". THIS IS PROOF!!! The ALPHA CAN MAKE POWER! Why swap it? Besides its a 2000 lb car for god sakes! 250 whp is enough to take on most street cars...300 is OVER KILL...not that its bad but damn...theres really no need for more unless your drag racing in Pro ciucuts.
Old Jul 9, 2008 | 08:03 AM
dbramagedprod's Avatar
Vehicle: 2001 Hyundai Accent
<div class='quotetop'>QUOTE(Fintile @ Jul 9 2008, 01:37 AM) </div><div class='quotemain'>How about NOT... I love that its the Alpha...too many people keep saying "Beta swap for real power". THIS IS PROOF!!! The ALPHA CAN MAKE POWER! Why swap it? Besides its a 2000 lb car for god sakes! 250 whp is enough to take on most street cars...300 is OVER KILL...not that its bad but damn...theres really no need for more unless your drag racing in Pro ciucuts.</div>
HAHA
Old Jul 9, 2008 | 12:06 PM
busy_squirrel's Avatar
Vehicle: 02 accent
<div class='quotetop'>QUOTE(Fintile @ Jul 8 2008, 11:37 PM) </div><div class='quotemain'>300 is OVER KILL...not that its bad but damn...theres really no need for more.</div>
There is no such thing as too much. That's why you a gas pedal and brake. the driver decides how much they want to use. tongue.gif
Old Jul 9, 2008 | 08:26 PM
Fintile's Avatar
Ok ok...fine be that way. I'm only thinking LOGICALLY about it. I stand my ground about the Beta swap. Only reason I would be JEALOUS about it is if I couldnt make power with what I had. I rather save myself the headache and boost the Alpha. Besides we are still yet to see some reliable Beta turbo Accents that havnt had to go through huge amounts of customization just to get it to all fit. I'm not say it hasnt been done just not many of you who have Beta swapped have been successful at it. Trying to boost an Alpha is challenge enough for me thank you.
I say over kill to 300 whp because I got a buddy whos running an Evo VIII motor swaped Mirage 1.6 Turbo guy had to downgrade his car from 435 whp to 320 because he couldnt get traction from 1st till the top of 3rd! He did have TOO MUCH POWER. His car is also 300-500 lbs heavier than ours... about 2500-2700 lbs.some where in that ball park.
Old Jul 10, 2008 | 02:06 AM
Ryanator's Avatar
When im driving down the highway at 100kmh about 60mph i think, It smokes the tyres in 5th gear by just poping the clutch! hehe... smile.gif lol. I just need a better gearbox then i can boost even more power... thinking of upgrading NOS to 150HP....
Cheers Ryan
Old Jul 15, 2008 | 06:48 PM
Fintile's Avatar
Good god...LOL...All I care about is that this little car can handle 200 whp with no prob. Good for you man keep it up. I look forward to seeing how far you take it. This is the same engine you first bought the car with right?
